Restrict user's running applications
17 years 7 months ago #23184 by GTM
Hi guy's i was wondering if any of you know of an application that can stop user's from running 3rd party applications. The user's in question do not have local admin rights however they are sending application files via email or usb sticks and running them from that so there is not a full installation on the machine. An example would be using different browser's than what we have set up bypassing our group policy proxy settings. Any help would be appreciated. Cheers.
17 years 7 months ago #23190 by skepticals
Which operating system are you using? I know Microsoft has the ability to create a whitelist of applications, but this seems like a pain in the neck.
I would be interested in solutions to this problem as well.
17 years 7 months ago #23191 by GTM
All the machines are windows xp..
17 years 7 months ago #23193 by Smurf
Depends really on your budget. Websense's Client Policy Manager is pretty good and quite flexiable. Ofcourse, some HIDS can probably also do this by adding the signatures or the files that are not allowed (or you can do it the other way around and install what they can use and then block everything else).
17 years 7 months ago #23194 by GTM
Im pretty sure the budget wont be a problem. So in your opinion Smurf would websense be the best bet ?
17 years 7 months ago #23195 by Smurf
I would do a little more research but what i have seen from Websense, the client policy manager is pretty good, not sure how the licensing works i.e. if you can get this on its own. Anyhow, here is a link, when i did my training on it the CPM looked pretty impresive but its not something we can install in our environment becauase we don't own the equipment. www.websense.com/global/en/ProductsServi...ClientPolicyManager/
There are others, Sophos Anti-Virus are also doing application control within their AV but currently its only got a limited number of applications within its database, their next release also has Removable Drive restrictions built in so you can stop users from using USB Pen Drives and the like. www.sophos.com/security/topic/application-control.html
You can do it in Group Policy for free but it can be a pain to configure.
Other google searches
www.google.co.uk/search?ie=UTF-8&oe=...ion+endpoint+control
www.google.co.uk/search?hl=en&q=appl...tnG=Search&meta=
Wayne
