127.0.0.1
20 years 5 months ago #5533 by beexo
127.0.0.1 was created by beexo
Strange thing is happening with my PCMCIA card (Xircom 10/100). It's working properly. But When I Ping with 127.0.0.1 It doesn't respond.
Anyone want to guess why?
20 years 5 months ago #5534 by FallenZer0
Replied by FallenZer0 on topic Re: 127.0.0.1
What OS? Do you have a Firewall?
20 years 5 months ago #5555 by beexo
Replied by beexo on topic Re: 127.0.0.1
Mandrake 10.
Using the command: ping 127.0.0.1
20 years 5 months ago #5556 by senior
Replied by senior on topic Re: 127.0.0.1
If you're using a firewall, it's probably blocking ICMP.
20 years 5 months ago #5559 by FallenZer0
Mandrake 10.
--See if there is an entry in the Routing table for 127.0.0.1 I think the command is route -n.
Also, use ifconfig lo and see if it says UP LOOPBACK RUNNING.
Let us know.
20 years 5 months ago #5583 by beexo
No firewall installed in this computer.
When I "route -n", the address 127.0.0.1 does not appear. In fact, if I switch on the computer without a lan connection, thre routing table is completely blank.
"ifconfig lo" does show "UP LOOPBACK RUNNING".
