Methods of measuring network throughput
16 years 1 month ago #29417 by skepticals
What are some ways that I can measure the actual throughput between PCs/Servers/Switches...
I know that I can run speed tests to a web server like speakeasy.net... but what about internally between two switches or PCs?
16 years 1 month ago #29418 by Alans
You can test it by copying a certain file from the second PC/Server to the remote one and see the transfer rate
that will be in Windows explorer... also you can use FTP to see howmuch data transferd in howmnay seconds..
always Face your Fears...
16 years 1 month ago #29420 by TheBishop
That's the way to do it. It won't show you the maximum throughput though because of the overhead of the OS and the chosen file copy mechanism will throttle the throughput somewhat. I've also found it's worth repeating the test say five times and taking the average as little bits of disk activity or other traffic on the network can easily skew a single result. The file size can also affect the result - I tried a huge file once and saw mega-throughput fr the first ten seconds or so until the cache memory in the disk controllers ran out, then it settled back to a slower rate. To see things like this, have task manager or perfmon showing the network performance on the machine while the test runs
16 years 1 month ago #29430 by Smurf
16 years 1 month ago #29434 by r0nni3
I use IPerf its a nice program with a pretty little GUI.
It gives you the option of using UDP or TCP too. :P
sourceforge.net/projects/iperf
Certifications:
CCNA - Have it
CCNA Security - Have it
CCSP - Almost!!!!
16 years 1 month ago #29435 by skepticals
Thanks for the replies. I will look into the programs. I have heard of IPerf before, but have not really used it.
