Bandwidth Control for ISPs
16 years 3 months ago #28531 by Alans
I want to know how ISP allocate bandwidths for each client?
like they have a client with 128 DL kbps and another with 512 kbps DL
Another question (related): is that possible to use Frame Relay between a router and a LAN? I mean if we have a LAN with Exchange server for example and other servers, how can I limit the bandwidth for each server from the router?
Is that possible to use Frame Relay from the router that connected to same switch of servers?
regards,
always Face your Fears...
16 years 3 months ago #28532 by novembre
It would depend on the WAN access technology being used. i.e. for FR / ATM you can set a CIR / PIR on the PVC, for Ethernet you can use Layer 2 rate limiting on the VLAN. Or if you wish to supply a full speed circuit you can limit at certain point or your network, like the egress edge - customers would have full speed within your network and then be limited as they leave, you can do this with a Layer 7 policing box - like the Cisco SCE.
For your other question I would use Ethernet and rate limit per VLAN.
16 years 3 months ago #28538 by Alans
Thanks.. but rate limit will not let us to use less than 1 M..
what if i want to limit each server to 128 kbps?
16 years 3 months ago #28539 by novembre
where do you get the 1mb limit? on my 1720 the minimum input/output rate limit value on a fastethernet subinterface is 8000 bits.
16 years 3 months ago #28540 by Alans
i saw it in some websites..i think thye used srr ...etc comand
could you please be more specific like show me commands and how to control both inbound and outbound connections on a certain port on the switch?
16 years 3 months ago #28577 by novembre
maybe (: what switch / router model are you doing this on?
Time to create page: 0.224 seconds
