how to connect 2 different IP Address
16 years 8 months ago #27034 by helloworld
Hello guys,
I have problem in connecting 2 different IP Address.
I have 192.168.18.0/24 and 192.168.1.0/24 they are connected to DLINK 3326SRM Switch. How can I connect host computer from 192.168.18.0/24 to 192.168.1.0/24 and vice versa.
What will be the routing table in DLINK 3326SRM?
Thank you in advance.
16 years 8 months ago #27036 by SteveP
They're two separate networks so you can't connect them via a switch. You'll have to use a router or reassign the addresses to be in the same network. I'm not familiar with the switch that you're using.
16 years 8 months ago #27038 by helloworld
The switch is a layer 3 switch.
Is there any way to connect the two networks?
16 years 8 months ago #27040 by S0lo
Sure there is if it is a layer 3. Not sure how to configure D-link's though, If you need the manual for this model, it's here: www.retrevo.com/support/D-link-DES-3326S...ual/id/420bh240/t/2/
16 years 8 months ago #27042 by Elohim
If it's a layer 3 switch, assign the respective ports to different VLANs and assign IP addresses to the VLAN interface and you will have connectivity between the subnetworks. You need to set the default gateway on the PCs to the IP address of the VLAN interface.
16 years 8 months ago #27043 by S0lo
Ooops :oops:, I said you needed RIP or OSPF, that is incorrect. Elohim is right. Don't know what got in my head!!
