- Thank you received: 1
Changing Network IP range
17 years 7 months ago #23072
by Alans
always Face your Fears...
Changing Network IP range was created by Alans
hi, if i want to change the IP range of our network that contain
40+ pcs and a domain controller, is there any critical
things that i should do or not to do to proceed with this IP changing?
thanks
thanks
17 years 7 months ago #23077
by DaLight
Replied by DaLight on topic Re: Changing Network IP range
A few pointers - sorry if some may be blindingly obvious.
Obtain a definite list of all devices with static IPs. All sorts of devices like printers, even switches with management IPs, etc can be hiding away on your network. These will obviously need to be manually changed over to the new range.
Ensure that any IP-based access control lists anywhere in your network are updated.
- skepticals
- Elite Member
17 years 7 months ago #23079
by skepticals
Replied by skepticals on topic Re: Changing Network IP range
Also, if you are using DHCP make sure you set the server to give out correct IPs for the computers and internal DNS server (if you are using one).
17 years 7 months ago #23087
Replied by TheBishop on topic Re: Changing Network IP range
And don't forget your router/default gateway. At ther very least you'll need to change the address of the LAN interface there
17 years 7 months ago #23095
by Alans
Replied by Alans on topic Re: Changing Network IP range
thanks for the replies guys, but is there any way to roll-back the network if it didn't work properly?
can i backup a network?
- skepticals
- Elite Member
17 years 7 months ago #23097
by skepticals
Hummm... I wish it were that simple. I don't think there is a way to backup everything as a whole; however, you could backup individual config files, settings, etc.
I would say have good documentation and spend a great deal of time up front making sure you have identified all the static IPs that need to be changed.
