Sharing an ISP with 2 department
17 years 10 months ago #22543
by chewyikai
Sharing an ISP with 2 department was created by chewyikai
Hi ,
i would like to share 1 internet connection with 2 deferent department without both department seeing each other (something like vlan) but by using 2 standard routers. i have tried changing the 2 routers to different subnet mask 255.255.255.0 and 255.255.255.252 both wont be able to see each other in the my network places but it still can ping each other. is there any other way without using layer3 switches and highend routers.
17 years 10 months ago #22546
by DaLight
Replied by DaLight on topic Re: Sharing an ISP with 2 department
How are the routers connected together in relation to the ISP feed?
17 years 10 months ago #22549
by chewyikai
Replied by chewyikai on topic Re: Sharing an ISP with 2 department
well 1st router is connected to the modem to get a pppoe connection with the IP 172.16.0.1 SM 255.255.255.0 and the 2nd router is connected by pluging the wan interface of the 2nd router to the lan interface of the 1st router. Configured wan connection type as static and lan ip is 192.168.1.1 sm 255.255.255.252 .Both router can still ping each other. BTW for example if i setup a VLan using a L2 switch with this 2 rourter is it posible for the clients to view each other
17 years 10 months ago #22551
by DaLight
If all you're concerned about is internet access as opposed to setting up port-forwarding or remote access, then your current setup should work as long as router 2 is setup as a NAT router.
17 years 10 months ago #22552
by toddwoo
Replied by toddwoo on topic Re: Sharing an ISP with 2 department
I'm not sure I understand what your looking for.. But maybe just setup some ACL's to keep each network away from each other?
17 years 10 months ago #22553
Replied by S0lo on topic Re: Sharing an ISP with 2 department
Can router 2 ping the external IP that your router 1 gets from the ISP ? If not. did you setup a default route on your router 2 ?
