Connectivity witout default gateway.
- calicutbobby
- Junior Member
17 years 9 months ago #22437
by calicutbobby
Connectivity witout default gateway. was created by calicutbobby
Hi Can anyone suggest on this. Last week I had been to a place and observed that the default gateway was not specified and still we were able to browse. But I suppose that traffic was going through the Proxy which was set in the IE. But what confused me was other applications too was working fine without explicitily specifying the default gateway !!!! Could some one tell me how thr traffic knows the path to take when no default gateway has been specified.
17 years 9 months ago #22441
by Smurf
Replied by Smurf on topic Re: Connectivity witout default gateway.
Hmm, just a few things first;
1. What do you mean by other applications ? Are these internal applications such as e-mail services, etc... ?
2. Did you check the routing table ?
17 years 9 months ago #22443
by eylli
Replied by eylli on topic Re: Connectivity witout default gateway.
ProxyARP
may be configured there
this would be a net with much broadcasts
regards
regards
17 years 9 months ago #22444
by Smurf
Yup, that was my initial thought but this would depend in we are talking about internal applications ?
- calicutbobby
- Junior Member
17 years 9 months ago #22459
by calicutbobby
Replied by calicutbobby on topic Re: Connectivity witout default gateway.
Oops!! I forgot to specify that. The application was Skype which was installed by me and hence Iam sure no proxy was set. If the PC doesnt know where to sent the traffic then how would this application work?
I have not looked the routing table. Is it a nice idea to add a default gateway via "route add" command?
17 years 9 months ago #22465
by Smurf
Hi there,
Its best to add a default gateway through the TCP/IP properties. If however you have several subnets within your organisation, you may add then seperately using the route add. Most people would just use the default gateway.
I have never used Skype but you may find that it checks your IE proxy settings and will use the proxy server which is why this is working.
