Shorting a Power Supply
21 years 2 months ago #2240
by ZiPPy
ZiPPy
Shorting a Power Supply was created by ZiPPy
Looking for somebody that has some ideas or knows how to short a computer power supply. I need to power up a couple of fans that are keeping my routers cool.
Was suggested to use a paper clip and insert into 2 pins of the mobo connector.
ZiPPy
ZiPPy
ZiPPy
21 years 2 months ago #2242
Replied by Chris on topic Re: Shorting a Power Supply
Zippy,
How do you intend to 'short' a power supply in order to power up a couple of fans ? Shorting the power supply will either blow its fuse or trigger any auto-short protection it might have!
On the other hand, I'm guessing that you might be refering to shorting the 'soft-power' in order to switch it on;
Can you please clarify?
Cheers mate,
Cheers mate,
21 years 2 months ago #2253
by UHSsncmrm
Replied by UHSsncmrm on topic shorting a power-supply
Little confused on that one!
21 years 2 months ago #2269
by sahirh
Replied by sahirh on topic Re: Shorting a Power Supply
So thats what I've got wrong all these years.... I spent so much money on these damn spike strips and voltage stabilizers thinking that I was suppost to prevent stuff like that from happening..
Anyway, I'll just short circuit this here SMPS and ***BZZZZAAAPPPPPP***
NO CARRIER
NO CARRIER
21 years 2 months ago #2274
by tfs
Tom
Replied by tfs on topic Re: Shorting a Power Supply
Very funny, I hope this isn't catchin***BZZZZAAAPPPPPP***
NO CARRIER
NO CARRIER
Tom
21 years 2 months ago #2277
by sahirh
:roll: This humour thing is getting out of ***BZZZZAAAPPPPPP***
NO CARRIER
NO CARRIER
Time to create page: 0.312 seconds
