Boson and OSPF
18 years 1 month ago #17194 by S0lo
Boson and OSPF was created by S0lo
I really need help on this, I'm preparing for CCNA and I have a question on configuring OSPF on boson simulator.
I've setup a network and configured it using RIP, RIP v2, EIGRP and on each setup routing works fine. (each in a seperate setup)
When I came to OSPF I configured it as the book says, However. It does not work properly. The routing tables do not always get filled with all configured subnets !! as a result, some parts of the network is unreachable. I'v put the topology and device configs files in a zip file that you can download here:
www.l0phtbox.net/other/y-net.zip
I'm fed up with it :? I'd appreciate it if some one can tell me were I went wrong.
18 years 1 month ago #17196 by Elohim
Replied by Elohim on topic Re: Boson and OSPF
Post the text config of each router and your network diagram
18 years 1 month ago #17199 by S0lo
Replied by S0lo on topic Re: Boson and OSPF
There you are:
1. Topology File (y-net.top):
[General]
NumberOfRouters=6
NumberOfSwitches=3
NumberOfPCs=2
NumberOfConnectors=10
Version=6.0.315
[Router1]
Hostname=Router 1
Devicename=Router 1
Series=2500
Model=2501
Ethernet=1
FastEthernet=0
GigabitEthernet=0
Token=0
Serial=2
Bri=1
xpos= 6930
ypos= 1920
[Router2]
Hostname=Router 2
Devicename=Router 2
Series=2500
Model=2501
Ethernet=1
FastEthernet=0
GigabitEthernet=0
Token=0
Serial=2
Bri=1
xpos= 6840
ypos= 4140
DCE=0/0
[Router3]
Hostname=Router 3
Devicename=Router 3
Series=2500
Model=2501
Ethernet=1
FastEthernet=0
GigabitEthernet=0
Token=0
Serial=2
Bri=1
xpos= 8130
ypos= 5940
DCE=0/0
[Router4]
Hostname=Router 4
Devicename=Router 4
Series=2500
Model=2501
Ethernet=1
FastEthernet=0
GigabitEthernet=0
Token=0
Serial=2
Bri=1
xpos= 9720
ypos= 4050
DCE=0/0
[Router5]
Hostname=Router 5
Devicename=Router 5
Series=2500
Model=2501
Ethernet=1
FastEthernet=0
GigabitEthernet=0
Token=0
Serial=2
Bri=1
xpos= 9585
ypos= 2010
DCE=0/0
[Router6]
Hostname=Router 6
Devicename=Router 6
Series=2500
Model=2501
Ethernet=1
FastEthernet=0
GigabitEthernet=0
Token=0
Serial=2
Bri=1
xpos= 10485
ypos= 7785
[Switch1]
Hostname=Switch 1
Devicename=Switch 1
Series=2900
Model=2950
Ethernet= 0
FastEthernet= 12
GigabitEthernet= 0
Token= 0
Serial= 0
Bri= 0
xpos= 7785
ypos= 7380
[Switch2]
Hostname=Switch 2
Devicename=Switch 2
Series=2900
Model=2950
Ethernet= 0
FastEthernet= 12
GigabitEthernet= 0
Token= 0
Serial= 0
Bri= 0
xpos= 4665
ypos= 2355
[Switch3]
Hostname=Switch 3
Devicename=Switch 3
Series=2900
Model=2950
Ethernet= 0
FastEthernet= 12
GigabitEthernet= 0
Token= 0
Serial= 0
Bri= 0
xpos= 11280
ypos= 2025
[PC1]
Name=PC 1
Devicename=PC 1
xpos= 6435
ypos= 7725
Model=Win 98
[PC2]
Name=PC 2
Devicename=PC 2
xpos= 10410
ypos= 615
Model=Win 98
[Connector1]
dev1name=Router 1
dev2name=Router 2
dev1interface=Serial 0
connectortype=Serial
dev2interface=Serial 0
caption=R1S0-R2S0
[Connector2]
dev1name=Router 2
dev2name=Router 3
dev1interface=Serial 1
caption=R2S1-R3S0
[Connector3]
dev1name=Router 3
dev2name=Router 4
caption=R3S1-R4S0
[Connector4]
dev1name=Router 4
dev2name=Router 5
caption=R4S1-R5S0
[Connector5]
dev1name=Router 3
dev2name=Switch 1
dev1interface=Ethernet 0
connectortype=Ethernet
dev2interface=Fast Ethernet 0/12
caption=R3E0-S1EFast0/12
[Connector6]
dev1name=PC 1
dev2name=Switch 1
caption=PC1,E0-S1EFast0/1
[Connector7]
dev1name=Router 5
dev2name=Switch 3
caption=R5E0-S3EFast0/12
[Connector8]
dev1name=Router 1
dev2name=Switch 2
caption=R1E0-S2EFast0/12
[Connector9]
dev1name=PC 2
dev2name=Switch 3
caption=PC2,E0-S3EFast0/1
[Connector10]
dev1name=Router 6
dev2name=Switch 1
dev2interface=Fast Ethernet 0/11
caption=R6E0-S1EFast0/11
2. Multi Cinfig File (Y_Net_OSPF_Routing.nwc)
Number of Devices =11
Number of Routers =6
Number of Switches=3
Number of PCs=2
3. Router 1 config (Y_Net_OSPF_Routing1.rtr)
Version 12.1
service timestamps log uptime
hostname Router1
ip subnet-zero
interface Serial0
ip address 192.168.10.73 255.255.255.252
no ip directed-broadcast
interface Serial1
no ip address
interface Ethernet0
ip address 192.168.10.81 255.255.255.248
interface Bri0
no ip address
router ospf 100
network 192.168.10.80 0.0.0.7 area 0
network 192.168.10.72 0.0.0.3 area 0
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
no scheduler allocate
end
4. Router 2 config (Y_Net_OSPF_Routing2.rtr)
Version 12.1
hostname Router2
ip subnet-zero
interface Serial0
ip address 192.168.10.74 255.255.255.252
clock rate 64000
interface Serial1
ip address 192.168.10.65 255.255.255.252
interface Ethernet0
no ip address
shutdown
interface Bri0
no ip address
shutdown
router ospf 100
network 192.168.10.64 0.0.0.3 area 0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
5. Router 3 config (Y_Net_OSPF_Routing3.rtr)
Version 12.1
hostname Router3
ip subnet-zero
interface Serial0
ip address 192.168.10.66 255.255.255.252
clock rate 64000
interface Serial1
ip address 192.168.10.69 255.255.255.252
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
interface Bri0
no ip address
shutdown
router ospf 100
network 10.10.10.0 0.0.0.255 area 0
network 192.168.10.68 0.0.0.3 area 0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
6. Router 4 Config (Y_Net_OSPF_Routing4.rtr)
Version 12.1
hostname Router4
ip subnet-zero
interface Serial0
ip address 192.168.10.70 255.255.255.252
clock rate 64000
interface Serial1
ip address 192.168.10.77 255.255.255.252
interface Ethernet0
no ip address
shutdown
interface Bri0
no ip address
shutdown
router ospf 100
network 192.168.10.76 0.0.0.3 area 0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
7. Router 5 config (Y_Net_OSPF_Routing5.rtr)
Version 12.1
hostname Router5
ip subnet-zero
interface Serial0
ip address 192.168.10.78 255.255.255.252
clock rate 64000
interface Serial1
no ip address
shutdown
interface Ethernet0
ip address 192.168.10.89 255.255.255.248
interface Bri0
no ip address
shutdown
router ospf 100
network 192.168.10.88 0.0.0.7 area 0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
8. Router 6 config (Y_Net_OSPF_Routing6.rtr)
Version 12.1
hostname Router6
ip subnet-zero
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface Ethernet0
ip address 10.10.10.2 255.255.255.0
interface Bri0
no ip address
shutdown
router ospf 100
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
9. Switch1 config (Y_Net_OSPF_Routing7.rtr)
Version 12.1
hostname Switch1
ip subnet-zero
spanning-tree extend system-id
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
vtp Server
vtp domain bigdomain
interface Vlan 1
no ip address
no ip route-cache
ip classless
no ip http server
line con 0
line aux 0
line vty 0 15
end
10. Switch2 config (Y_Net_OSPF_Routing8.rtr)
Version 12.1
hostname Switch2
ip subnet-zero
vtp Server
interface Vlan 1
no ip address
no ip route-cache
ip classless
no ip http server
line con 0
line aux 0
line vty 0 15
end
11. Switch3 config (Y_Net_OSPF_Routing9.rtr)
Version 12.1
hostname Switch3
ip subnet-zero
vtp Server
interface Vlan 1
no ip address
no ip route-cache
ip classless
no ip http server
line con 0
line aux 0
line vty 0 15
end
And finaly here is the topology as an image: www.l0phtbox.net/other/y-topology.gif
18 years 1 month ago #17206 by Elohim
I believe your serial interfaces needs some from of encapsulation to start off with and then depending on type of network your serial interfaces are, you need to specify the type of OSPF network.
At the command prompt, post the out of
show ip ospf neighbor
from each of the routers.
18 years 1 month ago #17207 by S0lo
Here are they:
Router1#sh ip ospf neig
Neighbor ID Pri State Dead Time Address Interface
192.168.10.74 0 FULL/ 00:00:53 192.168.10.74 Serial0
Router2#sh ip ospf neig
192.168.10.69 0 FULL/ 00:04:54 192.168.10.66 Serial1
192.168.10.81 0 FULL/ 00:04:54 192.168.10.73 Serial0
Router3#sh ip ospf neig
192.168.10.77 0 FULL/ 00:06:41 192.168.10.70 Serial1
192.168.10.74 0 FULL/ 00:06:41 192.168.10.65 Serial0
10.10.10.2 0 FULL/ 00:06:41 10.10.10.2 Ethernet0
Router4#sh ip ospf neig
192.168.10.89 0 FULL/ 00:06:21 192.168.10.78 Serial1
192.168.10.69 0 FULL/ 00:06:21 192.168.10.69 Serial0
Router5#sh ip ospf neig
192.168.10.77 0 FULL/ 00:07:52 192.168.10.77 Serial0
Router6#sh ip ospf neig
192.168.10.69 0 FULL/ 00:07:11 10.10.10.1 Ethernet0
18 years 1 month ago #17209 by S0lo
I have 7 subnets in the network, shouldn't thier be 7 routes in each routers routing table. I'm getting only 5 subnets in Router 1
Router1#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route
Gateway of last resort is not set
192.168.10.0/24 is variably subnetted, 4 subnets
C 192.168.10.72/30 is directly connected, Serial0
C 192.168.10.80/29 is directly connected, Ethernet0
O 192.168.10.64/30 [110/128] via 192.168.10.74, 00:23:24, Serial0
O 192.168.10.68/30 [110/256] via 192.168.10.74, 00:23:19, Serial0
10.0.0.0/24 is subnetted, 1 subnets
O 10.10.10.0 [110/202] via 192.168.10.74, 00:23:19, Serial0
Also for example in router4, I'm getting 6
Router4#sh ip route
192.168.10.0/24 is variably subnetted, 5 subnets
C 192.168.10.68/30 is directly connected, Serial0
O 192.168.10.88/29 [110/64] via 192.168.10.78, 00:30:07, Serial1
O 192.168.10.64/30 [110/64] via 192.168.10.69, 00:30:07, Serial0
C 192.168.10.76/30 is directly connected, Serial1
O 192.168.10.72/30 [110/384] via 192.168.10.69, 00:30:02, Serial0
O 10.10.10.0 [110/64] via 10.10.10.1, 00:30:07, Serial0
The same for all other routers, I never get 7 routes. For EIGRP, RIPv2 all 7 were there!!
Time to create page: 0.137 seconds
