Dot11Radio-wireless router connection ???
- networker333
13 years 1 month ago #36579
by networker333
Dot11Radio-wireless router connection ??? was created by networker333
Hi everyone! i believe it's not difficult for you people to solve my prob, you are professionals guys! Well, thanks in advance... using cisco packet tracer, i need to connect 2 routers using wireless, i think the
Dot11Radio interface
is appropriate, using the
HWIC-AP-AG-B module on the routers.
- I managed to understand how to connect a router and a PC using that same method of Dot11radio (by consulting the samples available in Packet tracer).
-I also googled a lot to get configuration samples and notes, but STILL nothing...
-I need to connect 2 routers using dot11radio, ssid, etc and be able to ping each other interfaces.
-Can anyone plz help me with a simple sample of config or any URL to some notes, i would be grateful. and ASAP plz.
Thnx in advance, atleast for reading my post
networker333
networker333
Time to create page: 0.127 seconds
