dell inspiron switch off after power supply is off
- lmcares4u2003
- Junior Member
12 years 11 months ago #37013
by lmcares4u2003
dell inspiron switch off after power supply is off was created by lmcares4u2003
dell inspiron switch off after power supply is off i.e the charger plug is remove from socket outlet and the battery is fully charge, u have to power it on again and it wil now start to run from the battery. the antivirus (Avast 5.0) disappear from the system.......likely problem and solution pls reply
12 years 11 months ago #37042
by Nevins
Useful Threads
Replied by Nevins on topic Re: dell inspiron switch off after power supply is off
Let me see if I can define your problem better:
You have a Dell Inspiron Laptop.
In order to run the labtop on a battery you have to:
1.) Turn it off
2.) Unplug the power supply
3.) Turn it on again.
When running on the battery the antivirus (Avast 5.0) "disappears from the system".
Going to need more details on this issue.
Does the directory that holds the antivirus still exist when it's gone?
Is Avast5.0 the only thing that goes away when you reboot?
Is your Antivirus fully updated?
What are your power save settings?
1.) Turn it off
Useful Threads
Time to create page: 0.145 seconds
