Help with Cisco 2811 conf
8 years 6 months ago - 8 years 6 months ago #38688
by alesyl
Help with Cisco 2811 conf was created by alesyl
Hello, I'm new at Cisco and with the examples I have read here make my own conf
Can someone please check if I there is an error on my config
en
conf t
host name CR1
enable secret XXXXXX
no ip domain-lookup
ip classless
ip dhcp pool LAN
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 65.32.1.65 65.32.1.70
interface fastethernet0/0
description ** LAN **
ip address 192.168.0.1 255.255.255.0
ip nat inside
no shutdown
interface fastethernet0/1
description ** Internet **
ip address <ISP Static IP – Subnet Mask>
ip nat outside
no shutdown
ip nat inside source list 1 interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 <ISP Gateway>
access-list 1 permit 192.168.0.0 0.0.0.255
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
line vty 0 4
access-class 1 in
password Cisco
login
end
wr
en
conf t
host name CR1
no ip domain-lookup
ip classless
ip dhcp pool LAN
ip nat inside
no shutdown
ip nat outside
no shutdown
ip http server
line vty 0 4
access-class 1 in
password Cisco
login
end
wr
Last edit: 8 years 6 months ago by alesyl.
8 years 5 months ago #38692
Replied by Chris on topic Help with Cisco 2811 conf
Alesyl,
Your configuration seems like a very basic configuration, just enough to get you connected to the internet.
You should also configure access lists to limit access to and from the Internet, plus secure your router as much as possible.
You might want to also check out the auto-secure lockdown feature we've covered here:
www.firewall.cx/cisco-technical-knowledg...osecure-feature.html
Good luck.
Chris.
Good luck.
Chris.
The following user(s) said Thank You: sose
8 years 3 months ago #38699
by sose
sose
Network Engineer
Replied by sose on topic Help with Cisco 2811 conf
what are you trying to archive ?
sose
Network Engineer
Time to create page: 0.145 seconds
