FTP protocol out of port 21
10 years 4 months ago #38459
by johnyb98
FTP protocol out of port 21 was created by johnyb98
Good evening.
Is there a way to make ftp work at a port other than 21?
Thank you for your time!!
10 years 4 months ago #38460
Replied by Chris on topic Re: FTP protocol out of port 21
Johny,
The only way to make FTP work out another port is if the FTP server you are connecting to (assuming you're at the client's side) 'listens' on a different port. If you're at the server side, then it's up to the FTP server application if it allows you to configure the FTP service to 'listen' on a different port other than 21.
Hope that helps answer your question.
Chris.
Chris.
10 years 4 months ago #38461
by johnyb98
Replied by johnyb98 on topic Re: FTP protocol out of port 21
Chris, thank you for the answer.
I am talking about filezilla. According to what you say I think that the solution is to make ftp 'listen' to the desired port via ftp service (IIS manager) of the O/S, and then simply declare it on the ftp application (filezilla). Have I understood well?
10 years 4 months ago #38462
Johny, you are correct. Simply configure the IIS FTP service to 'listen' on a different port and then make the necessary port adjustments on your FTP client so that it connects to the FTP server at the same port the server is 'listening' on.
Good luck!
Chris.
Good luck!
Chris.
10 years 4 months ago - 10 years 4 months ago #38463
by johnyb98
Chris, thank you very much for your answers and your help!
John
John
Last edit: 10 years 4 months ago by johnyb98.
