DHCP LAN customers wont connect through CISCO 2620
10 years 3 months ago #38466
by wahid
DHCP LAN customers wont connect through CISCO 2620 was created by wahid
i'm configure cisco 2620 as a internet router. my cisco 2620 router has 5 Ethernet interface. One FE and four Ethernet interface. i'm configure the FE interface as ISP internet interface. and Ethernet 1/1 as a DHCP LAN interface. as i see my config are ok. but unable to access the internet from LAN side. below is my config. please help me to solve this.
Current configuration : 1498 bytes
version 12.2
service config
service timestamps log uptime
hostname xxx
enable secret 5 $1$LvPI$UtOZEPSXBrf
enable password xxxxxx
ip subnet-zero
no ip routing
ip name-server 100.12.13.13
ip name-server 200.100.12.12
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp pool insideDHCP
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
dns-server 100.12.13.13 200.100.12.12
call rsvp-sync
interface FastEthernet0/0
description Broadband Internet
ip address 20.110.211.154 255.255.255.240
ip nat outside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface Ethernet1/0
no ip address
no ip route-cache
no ip mroute-cache
half-duplex
no cdp enable
interface Ethernet1/1
description DHCP LAN
ip address 192.168.5.1 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
full-duplex
no cdp enable
interface Ethernet1/2
no ip address
no ip route-cache
no ip mroute-cache
shutdown
half-duplex
no cdp enable
interface Ethernet1/3
no ip address
no ip route-cache
no ip mroute-cache
full-duplex
no cdp enable
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 0.110.211.155
no ip http server
dial-peer cor custom
line con 0
exec-timeout 0 0
password xxxxxxx
login
line aux 0
line vty 0 4
password xxxxxxxx
login
end
version 12.2
service config
hostname xxx
ip subnet-zero
no ip routing
call rsvp-sync
ip nat outside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
no ip address
no ip route-cache
no ip mroute-cache
half-duplex
no cdp enable
ip nat inside
no ip route-cache
no ip mroute-cache
full-duplex
no cdp enable
no ip address
no ip route-cache
no ip mroute-cache
shutdown
half-duplex
no cdp enable
no ip address
no ip route-cache
no ip mroute-cache
full-duplex
no cdp enable
ip classless
no ip http server
line con 0
exec-timeout 0 0
password xxxxxxx
login
line aux 0
line vty 0 4
password xxxxxxxx
login
end
10 years 2 months ago - 10 years 2 months ago #38475
Replied by Chris on topic DHCP LAN customers wont connect through CISCO 2620
Wahid,
The problem seems to be a missing access list for your nat overload here:
We've got a comprehensive example for this scenario in our Configuring NAT Overload on Cisco router article.
Let us know if you are able to resolve your problem.
Good luck!
Code:
Good luck!
Last edit: 10 years 2 months ago by Chris.
Time to create page: 0.128 seconds
