[help] pptp vpn in cisco 1841
- fakhrul.coy
11 years 4 months ago - 11 years 4 months ago #38200
by fakhrul.coy
[help] pptp vpn in cisco 1841 was created by fakhrul.coy
what's wrong with my configuration PPTP VPN in cisco Router 1841 Series
error message from win 7 to vpn client
** Link Removed by Moderator **
configuration :
configuration :
Code:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot system flash c1841-ipbasek9-mz.124-24.T.bin
boot-end-marker
logging message-counter syslog
enable secret 5 $1$eb9Q$7kMUF5Am0kVn/QXwssfrD/
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
dot11 syslog
no ip source-route
ip cef
ip name-server 202.134.1.10
ip name-server 202.134.0.155
multilink bundle-name authenticated
vpdn enable
vpdn-group PPTP
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
vpdn-group uin
accept-dialin
protocol pptp
virtual-template 1
username ala***in password 7 051B131C2A4343
username fa***ul privilege 15 password 7 03520B59565F701C16594B51
archive
log config
hidekeys
interface FastEthernet0/0
ip address 222.124.x.181 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description ====LOCAL=====
ip address 192.168.100.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
interface Virtual-Template1
description ##PPTP TUNNEL##
ip unnumbered FastEthernet0/0
no ip redirects
no ip unreachables
no ip proxy-arp
peer default ip address pool PPTP_POOL
no keepalive
ppp authentication pap chap ms-chap
ppp timeout idle 360
ip local pool PPTP_POOL 192.168.101.110 192.168.101.125
ip default-gateway 222.124.x.161
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 222.124.152.161
no ip http server
no ip http secure-server
ip nat pool fahrul 222.124.x.181 222.124.x.181 prefix-length 29
ip nat inside source list 77 pool fahrul overload
access-list 23 permit 10.10.20.0 0.0.0.255
access-list 77 permit 192.168.2.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp host 203.197.12.30 eq domain host 121.243.96.154
access-list 101 permit ip 10.10.20.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 101 permit ip 10.10.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 101 deny ip 192.168.100.0 0.0.0.255 any
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
control-plane
line con 0
line aux 0
line vty 0 4
password 7 060506324F41
scheduler allocate 20000 1000
end
Last edit: 11 years 4 months ago by Chris.
Time to create page: 0.126 seconds
