How to fix a flat tyre
14 years 6 months ago #32641
by hades
I think therefore I am!
How to fix a flat tyre was created by hades
An engineer, a mathematician, and a computer programmer are driving down the road when the car they are in gets a flat tire. The engineer says that they should buy a new car. The mathematician says they should sell the old tire and buy a new one. The computer programmer says they should drive the car around the block and see if the tire fixes itself.
14 years 6 months ago #32642
by KiLLaBeE
Replied by KiLLaBeE on topic Re: How to fix a flat tyre
14 years 6 months ago #32652
by talk2sp
BORN TO BE GREAT
c0de - 3
Replied by talk2sp on topic without strings....
Hades without strings i will go by the computer programmer's decision. Why? cos the Engineer says they should get a new car (get a new car cos u have a bad Tyre). the Mathematician says they should sell the old one for a new one (makes little sense, what if no one buys a flat Tyre their journey will be delayed). the Computer Programmer says lets drive it around, it should fix it self (i so agree cos it depends on the kind of car and the Tyre itself) am very sure the comp programmer applied the if...then...else statement..
Work it?
C0DE - 3
Work it?
C0DE - 3
BORN TO BE GREAT
c0de - 3
14 years 6 months ago #32670
Replied by S0lo on topic Re: How to fix a flat tyre
hades, all three probably gona spend the night in the car.
KiLLaBeE, I couldn't stop the loughs :lol:
Here is another:
Arrivals: Blue Sky of Death
Here is another:
Time to create page: 0.134 seconds
