L3 switch with publec IP on the switch port
11 years 8 months ago #38138
by saidfrh
L3 switch with publec IP on the switch port was created by saidfrh
How do you configure an layer three switch and and assign one of the switch's port with a public IP address? An access list would be required on theperimeter router and firewall to allow the public IP to the switch port?
11 years 7 months ago #38139
by Nevins
Useful Threads
Replied by Nevins on topic Re: L3 switch with publec IP on the switch port
It's not really clear what you are asking here however if you want to assign an ip public or otherwise to an interface go into the interface configuration mode and use the ip address command.
Here is an example of intervlan routing where ip addresses are being assigned to "vlan interfaces":
Configure intervlan routing
Useful Threads
11 years 7 months ago #38140
Replied by S0lo on topic Re: L3 switch with publec IP on the switch port
A public IP is typically configured on the perimeter (edge) router, unless your own L3 switch is the perimeter, which I doubt.
It would help explaining your question further.
