Connecting and configuring an ASA from a Mac
13 years 2 months ago #36526
by sterrell
Connecting and configuring an ASA from a Mac was created by sterrell
Hi all,
As described in my last post, I got some surplus ASAs here at work. Problem is, we are issued MacBook Pros here. No serial ports. I have a USB to DB9/serial adapter connected to a Cisco cable into the console port of the ASA. I can't seem to connect to the ASA though. I need to be able to connect to it and then upgrade the IOS.
Any help would be appreciated.
13 years 2 months ago #36542
by rizin
Replied by rizin on topic Re: Connecting and configuring an ASA from a Mac
Review your previous post.
13 years 1 month ago #36606
by sterrell
Replied by sterrell on topic Re: Connecting and configuring an ASA from a Mac
This reminds me, I figured it out. With a serial to USB adapter, install the adapter's drivers and then open a terminal window and run the following:
ls -l /dev/tty.*
screen /dev/tty.usbserial
ls -l /dev/tty.*
