Monitoring Tools for monitor Cisco Router
14 years 10 months ago #30804
by dmourghen
Monitoring Tools for monitor Cisco Router was created by dmourghen
Hello
Guys do u know a tool that can be installed to monitor my cisco routers at office.
Thanks again.
Thanks again.
14 years 10 months ago #30807
Replied by TheBishop on topic Re: Monitoring Tools for monitor Cisco Router
What do you want to monitor? The traffic levels on your WAN ports? If so you could try MRTG. Do you just want to know the routers are still available? If so you could simply have a ping check running on them or go for something more elegant like one of the many network management solutions out there. Or if you want comprehensive configuration info and some support aids there's always Cisco Works
14 years 10 months ago #30861
by Chojin
Replied by Chojin on topic Re: Monitoring Tools for monitor Cisco Router
You will probably mean things like SNMP.
You can look for tools like Cacti, IP Monitor, PRTG, Cisco Works.
