problem with overloading
14 years 11 months ago #30730
by dmourghen
problem with overloading was created by dmourghen
access-list 2 permit any
ip nat pool ToInternet xx.xxx.xxx.xxx xxx.xxx.xxx.xxxnetmask 255.255.255.248
ip nat inside source list 2 pool ToInternet overload
ip nat inside source static tcp xx.xx.xx.199 25 xx.xx.xx.xx 25
ip nat inside source static tcp xx.xx.xx.12 80 xx.xx.xx.xx 80
ip nat inside source static tcp xx.xx.xx.12 110 xx.xx.xx.xx 110. Blackberry Access
ip nat inside source static tcp xx.xx.xx.12 110 xx.xx.xx.xx 1352. Lotus Monitoring Tool
My problem is that it works and then after sometimes It stops to send mails but I do receive my mails. Furthermore I need to clear my ip nat translations to receive again.
Thanks to advise.
Thanks to advise.
14 years 11 months ago #30744
Replied by S0lo on topic Re: problem with overloading
In the last two lines,
[code:1]ip nat inside source static tcp xx.xx.xx.12 110 xx.xx.xx.xx 110. Blackberry Access
ip nat inside source static tcp xx.xx.xx.12 110 xx.xx.xx.xx 1352. Lotus Monitoring Tool [/code:1]
You are mapping both global ports 1352 and 110 to the same port 110 to what appears to be the same IP xx.xx.xx.12. Are you sure this is not a typo or is this meant?
For your problem with mail. I'd try to isolate the problem by simplifying the config. You could temporarily delete those lines:
[code:1]ip nat inside source static tcp xx.xx.xx.12 80 xx.xx.xx.xx 80
See if the problem comes again. If it doesn't, you could add the other commands one by one until you catch the problem again.
ps. It would help if you post your whole config.
14 years 10 months ago #30767
by dmourghen
Replied by dmourghen on topic Full configs
Building configuration...
Current configuration : 1837 bytes
version 12.4
service password-encryption
hostname rtcisco
boot-start-marker
boot-end-marker
logging buffered 4096 informational
enable secret 5 xhgghjgyhghjghjghjg
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip rcmd domain-lookup
ip rcmd rsh-enable
ip rcmd remote-host cisco 11.1.1.51 cisco enable
ip rcmd remote-host cisco 11.1.2.51 cisco enable
interface FastEthernet0/0
ip address 192.168.2.10 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.50.170 255.255.255.252
ip nat outside
encapsulation frame-relay IETF
frame-relay interfac
frame-relay lmi-type q933a
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.50.169
ip route 11.1.1.0 255.255.255.0 192.168.2.1
ip route 11.1.2.0 255.255.255.0 192.168.2.1
no ip http server
ip nat pool ToInternet 198.30.63.64 198.30.63.64 netmask 255.255.255.248
ip nat inside source static tcp 192.168.2.199 25 198.30.63.64 25 extendable (Barracuda Anti-Spam Device)
ip nat inside source static tcp 192.168.2.23 80 198.30.63.64 80 extendable (For Web Mail Access)
ip nat inside source static tcp 192.168.2.23 110 198.30.63.64 110 extendable (For blackberry Access)
ip nat inside source static tcp 192.168.2.23 1352 198.30.63.64 1352 extendable (For Lotus Domino Monitoring)
ip nat inside source static 192.168.2.24 198.30.63.64 (Access Router outside)
logging source-interface FastEthernet0/0
logging 11.1.1.31
logging 11.1.2.31
snmp-server community mimidou RO
control-plane
line con 0
line aux 0
line vty 0 4
password 7 xhgghjgyhghjghjghjg
login
end
Ammar this is the full configs, I am really stuck with that, the mails comes in but does not go out. But when I clear the ip nat it seems to be ok. Our spam is Barracuda.
version 12.4
hostname rtcisco
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
mmi snmp-timeout
ip subnet-zero
ip cef
ip rcmd rsh-enable
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip nat outside
ip classless
no ip http server
logging 11.1.1.31
logging 11.1.2.31
control-plane
line con 0
line aux 0
line vty 0 4
login
end
14 years 10 months ago #30768
Do you still have internet access when the problem happens? I mean can your LAN hosts browse internet normally after the problem occurs?
I'm asking because you have only one public IP (198.30.63.64) for the NAT pool but your using it to do both dynamic NAT and static NAT. Usually, you need at least one additional IP to do static NAT.
Check to see what happens if you remove the following line:
[code:1]ip nat inside source static 192.168.2.24 198.30.63.64[/code:1]
14 years 10 months ago #30769
by dmourghen
No we don;t have internet access. and actually it a mail server and the mails does not go out.
Well we have another addres which is 198.30.63.65 but when we this one as nat pool when people send mails , it prompts that there is no reverse DNS
Nothing happens when I remove the lines. its the same as before.
14 years 10 months ago #30773
by dmourghen
Replied by dmourghen on topic Som other info
I have noted that there is anlot of traffic coming out and port 135 and 445 is highly being used by the router.
the server has symantec and all patch has been applied on the server.
Time to create page: 0.146 seconds
