design and implementation of network segment of 3 vlan
- lmcares4u2003
- Junior Member
13 years 1 month ago #36742
by lmcares4u2003
i was given this as a project topic , i need ur help too, please put me through, i need your idea, what to do?
13 years 1 month ago #36750
Replied by S0lo on topic Re: design and implementation of network segment of 3 vlan
If you could elaborate on the requirements and the evironment of the project it would help us help you.
- lmcares4u2003
- Junior Member
13 years 1 month ago #36770
by lmcares4u2003
Replied by lmcares4u2003 on topic Re: design and implementation of network segment of 3 vlan
with the little idea i have about networking, i have downloaded some material about the project, the supervisor said i should forget about using the cisco swicth, and is the only cisco swicth that can be use to create a VLAN, now he said i should normal 8port switch and then go ahead with the project. it is an undergraduate project(finalist).
pls replyyyyyyyy
pls replyyyyyyyy
13 years 1 month ago #36771
Here is a quicky starter network with 3 subnets, one for each switch. The whole network is connected to single router as you can see. Each switch is connected to a certain department or sector of the company.
img01.imagecanon.com/full_view.php?view=29458_3subnets.jpg
The first thing you want to do after setting up the devices is to assign different and valid IP address ranges for each subnet.
13 years 4 weeks ago #36785
by rizin
Replied by rizin on topic Re: design and implementation of network segment of 3 vlan
Your image is Missing S0lo
13 years 4 weeks ago #36789
Thanks rizin, I've replaced the link. For some reason the [img] code didn't work.
Time to create page: 0.142 seconds
